Anti-sway bar
I rarely need some help but be brave and ask. I need some advise on how to install it the Anti-sway bar. I changed out the bushings. I got the 3in suspention. So the bar is not perfectly lined up when I try to install it. I got the book's way to install the anti-sway bar, which it says just bolt in and install, so it dont help me much. I just wanted some pointers if anyone had done this with the lift. I was thinking of getting out the floor jack and try to jack up the bar to twist it alittle. 4wd 93
it should mount alright the only thing you really need to watch tho is the pivot/cup-ball socket on each end of the sway bar kuz they`re like a ball joint and they can only have so much flex in them and if you flex them too much they will break off
nice I was just gonna do this on my truck got the bushings sitin in the truck.
Try unloadin the suspension and maybe puttin a jack under the A-arm maybe that well help relieve the tension?
Im gonna do this on my truck this weekend to see if i have the same problem
For such a simple project it was a PITA for me. Like I said above due to the lift the sway bar would not line up with the lower control arm. I had to get out the jack and twist up the bar. Then had to get my Giant c-clamp and cranck the bar back onto the control arm. Then I had to get a cranking strap and postion the bar upwards. All in all it took an hour. Hopefully Fox you have better luck at it then me. Its all taken care of.
