93 dakota-cig lighter fuse?
Old Dec 16, 2008 | 01:17 PM
sawdustmike3's Avatar
sawdustmike3
Default 93 dakota-cig lighter fuse?
Cig lighter not working- not sure which fuse on panel. Don't smoke, just want to use small heater this winter. Typicall dakota - heater sucks. thanks mike
Old Dec 16, 2008 | 01:32 PM
Crazy4x4RT's Avatar
Crazy4x4RT
In the FAQ in this section you can find a fuse pannel diagram. You might want to try flushing out your heater core this may help.
Old Dec 16, 2008 | 06:46 PM
1shotjake's Avatar
1shotjake
are you sure its a fuse? I thought the same on mine, but I just pulled the assembly out of the dash, disconnected it all, cleaned the contacts, put it back in, and mine worked. It's possible you just have a bad connection. Could still be the fuse, but i'd check that if you can't find the fuse, or it's not blown.
