93 Dak idle problem.
Old Dec 17, 2008 | 07:52 AM
93dakota4x4's Avatar
93dakota4x4
Default 93 Dak idle problem.
i got a 93 dakota 5.2 , stalls when its hot , and is hard to start when hot. I unplugged a vacuum line and it works fine other than ideling rough when its cold. i think it may have somthing to do with the IAC but want a second opinion. thanks
Old Dec 17, 2008 | 10:13 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The IAC is the usuall cause of Idle problems. Take it off and make sure it can move freely. Clean it up and replace it if you need to. You said its hard to start, have you tried pressing the gas when starting. Does that help or no. If vacuum helpes your engine then the MAP sensor may be your problem.
Old Dec 18, 2008 | 07:27 AM
93dakota4x4
before i unplugged the pcv vacuum line i had to keep the gas pedal down a ways to start it when it was hot
