95 dakota shuts off after running for 10 minutes
the truck will start up, run for about 10 minutes then just shut down. It has fuel splashing up out of the throttle body just after it shuts down. I also am getting code 27 but do not seem to fid out what this means beside fuel control circuit. i have replaced the fuel pressure regulator and the o2 sensor. but that has had no effect on the shut down problem. I also have checked the spark just after it shuts down and the spark will jump a good half inch.any body got any ideas
roysduster
roysduster
could be an issue with the wiring in the fuel pump relay or it's circuit. there is a splice in there similar to the ASD splice. I had a similar issue on my '92 and i took a stab and won with the ASD splice, but I also had an ASD code where as you have a fuel control code, so I'd check the fuel relay and/or the circuit.
