1992 Dodge Dak wont start in cold
Old Jan 4, 2009 | 11:24 AM
curto182's Avatar
curto182
Default 1992 Dodge Dak wont start in cold
the truck is a 3.9 V6 and in good condition but for some reason it wont start in the cold pretty much anything below -7 C , it has no problem starting in warmer weather. iv replaced the starter and solinoid, replaced the wires and fuses. i dont know what else it could be
Old Jan 4, 2009 | 11:30 AM
dodgerules86's Avatar
dodgerules86
What exactly is it going?
Turning over but not quite "catching"? Not turning over at all? Turning over weakly?
Could be a weak battery.
Old Jan 4, 2009 | 01:16 PM
curto182's Avatar
curto182
no, it doesnt click from the starter and iv checked the battery and its reading 12 volts, could it be the N or P switch, or the relay switch
Old Jan 4, 2009 | 04:28 PM
dodgerules86
I'd swap the relay.
If that doesn't work, try starting in neutral, or jiggling the gear-shift around when in park or neutral. When I replaced my transmission, I initially had problems starting in Park. I had to really jam the gear-shift up for the switch to provide a good ground.
If that doesn't work, I'd get a multimeter, pull that relay, and start checking for power and grounds at the proper pins.
Because, if I think right, if it was just a bad/weak battery, you would at least get a "click" or it would try to turn over.
