dash lights
Old Jan 23, 2009 | 10:14 AM
lerch73's Avatar
lerch73
Default dash lights
what would cause the dash lights not to work?
Old Jan 23, 2009 | 11:27 AM
pashadowops's Avatar
pashadowops
Is it just the dash lights or did all the interior lights go out?
Did you make any changes prior to the dash lights going out?
I had a problem where all my interior lights went out including my dash and radio. It turned out to be a 5amp fuse under the dash and a 50amp fuse in the PDC under the hood.
Old Jan 23, 2009 | 11:53 AM
dodgerules86's Avatar
dodgerules86
Most times if its just the dash lights are out (for instance, the stock radio and heater control lights still light up), its just the connector on the back of the cluster assembly isn't making good contact. There isn't really any way around it: you have to remove the cluster assembly, disconnect the connector, and add some dielectric grease. It's been working pretty flawlessly for me for 3 years now.
Old Jan 23, 2009 | 12:19 PM
lerch73's Avatar
lerch73
it is just the dash lights.
no i haven't made any changes since they went out.
the dash lights never worked since i bought the truck.
Old Jan 23, 2009 | 12:21 PM
dodgerules86
Yea, your gonna need to take the cluster out and get to those electrical connectors.
Old Jan 23, 2009 | 12:26 PM
lerch73's Avatar
lerch73
ok .what 50 amp is it in the PDC?
Old Jan 23, 2009 | 12:41 PM
dodgerules86
You disconnect the electrical connector. inspect both the connector and the pin that goes into it to make sure its not corroded and that the pin is not bent or broken. Than add dielectric grease. Go to https://dodgeforum.com/m_550094/tm.htm and read it.
The exact pin might not be the same, so just add a tiny bit of the dielectric grease to each pin. Please note: a tiny bit. Too much and it will push itself out of the pin when you reconnect the connector and could cause some problems.
If it was a fuse, you wouldn't have heater control/radio back lighting either. It's not a fuse. 99% its the connector on the back of the cluster.
Old Jan 23, 2009 | 01:25 PM
lerch73's Avatar
lerch73
i don't have the heater control lights either
Old Jan 23, 2009 | 01:32 PM
dodgerules86
Oh, well, you fooled me by the statement above:
"it is just the dash lights." in response to me saying, "Most times if its just the dash lights are out (for instance, the stock radio and heater control lights still light up)..."
Old Jan 23, 2009 | 02:29 PM
pashadowops
The fuses are marked under the PDC lid. But I have attached pics below. The fuse the pen is pointing to the one you want.
