What happened with your experience?
Old Jan 25, 2009 | 01:01 AM
nick_boles's Avatar
nick_boles
Default What happened with your experience?
Ok so i've gotten some good stuff from the site and especially the faqs but I wanna know what problems or experiences have you guys personally encountered with the 318 swap on an 88. I want to hear any suggestions of things you wish you had done, snags you hit along the way, little things you took for granted, or things you had alot of problems with. Any and all suggestions and ideas are more than welcom as I am about to make the swap pretty soon. So thanks for any posts in advance guys...
Old Jan 25, 2009 | 05:18 PM
codydakota's Avatar
codydakota
I haven't actually done one myself, but one of the things i hear most often is clearance for the fan (the rad support is set farther back on the earlier daks than on the newer 1st gens). They remedy this with an electric fan setup. Other than that, I haven't heard too much complaints, just amke sure the trans is compatible with the motor and that the mounts are where you need them and you're good to go.
Old Jan 27, 2009 | 05:20 PM
lilreddakota's Avatar
lilreddakota
check out FAQ there is a list of what you need and problems that you may run into
