91 dakota fuel gauge problem
Old Feb 6, 2009 | 12:04 PM
incubustaproot's Avatar
incubustaproot
Default 91 dakota fuel gauge problem
the needle swings widely, often below E. It rests at 1/4 tank when the truck is off. When i turn it on the needle starts to go crazy (mentioned above) Strangly though, when i fill the tank up it reads perfect down to about 7/8-3/4 tank then it goes haywire when it drops below that amount. The low fuel light still works fine tho.
any suggestions? thanks!
Old Feb 6, 2009 | 10:01 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The fuel level sensors were a big problem on these trucks. It may just be the connectors are corded. There is a small write up in the FAQ about this issue.
Old Feb 6, 2009 | 10:43 PM
mr.318's Avatar
mr.318
Also theses trucks are know for bad floats, Had to replace my fuelpump to fix my gauge
