Rear Shock Bolt
Guys,
I pulled into work today to find one of my rear shocks dragging. I need to know what kind of bolt/nut to get to replace the one that fell / broke off. Any information on this would be greatly appreciated.
Just kidding... I just looked at the manual and they look the same. There are 2 bolts/nuts holding it on at the top and one on the bottom (you didn't say which one broke). If they are completely gone then I dont think it matters what you put back in, as long as the bolt fits through the hole and get a nut with a matching thread pattern. I wish I could remember the size from when I replaced my shocks but I think its somewhere around 1/4 to 3/8 inch on top and 1/2 to 5/8 or so on bottom. Just out of curiosity, did you look to make sure the crossmemeber/bracket that holds the upper bolts for the shock isn't broken (if it was the top that fell), cause it seems odd that they would come out. I just remember what a pain it was and how much penetrating oil I had to use before they finally broke free when I replaced my shocks.
Oh sorry. Its the bottom bolt that secures the shock to the axle. I dunno if it broke or finally worked itself loose. But I think I will get matching setups for each side. I called two Dealerships and they each gave me two different answers, but both agreed that its a 1/2 bolt /nut. I will just make a trip to the farm/home store. I know they have Grade A 1/2 bolts there.
Oh, I was told that Grade A, was the best. But purhaps he meant grade 8. Yeah definitely going with the washer on each side and a locking washer on the nut side.
Trending Topics
Awesome! Just out of curiosity, did you just replace the shocks and not tighten down the nuts? cause mine were so tight the first time I took them off that it's hard to believe they'd fall off on their own.
