i am wanting to turbo mine too and i have seen the turbos mounted on the pass. side and the crossover pipe running under the front of the engine. i will look in the j yard and see if i see one with manual steering
Thanks for the help. Just let me know if you find one. I dont always login and check pm's unless i am at work and I am a shift worker so if I dont get back to you quick it doesnt mean I am not intrested. Thanks again.
The dealer told me manual steering was only an option on the 4cyl when I tried to buy a non power steering belt for my V8. I got a non A/C belt and added a idler. The manual rack also uses a different spline coupler. This smaller coupler was $175 but is now discontinued. Flaming river may have one but they could only tell me the sizes they have not what they fit
ok, I dug it out, it's complete tie rod to tie rod (you'll need new boots) and it's got the U-Joint / splined assembly still on it - I just pulled the telescoping rectangular rod out of the slipjoint.
I wont have the belt issues. My engine is a L/A and has v-belt and removing the psp will be easy. all i need to do is change my water pump pulley to tie in with the alt and remove the ps pump and I am good to go.
Would you have any idea what shipping would be? 50 Sounds good to me.
Hey dirtball and 408Ram, did ya'll finish your deal for the rack, if not, dirtball, if you still have it and want to get rid of it, please let me know. Thanks, Scott.
