new with a 92
Old Mar 3, 2009 | 05:26 PM
primered92dakota's Avatar
primered92dakota
Default new with a 92
Hi, I am new to the forum. I have a 92 Dakota that I don't really have the money to take to a shop, and I don't have the knowledge of them to diagnose the actual issue.
The truck has been doing this for a while, and is now getting worse. It will drive fine for a bit then suddenly die. While stranded on the side of the road, we wait for the truck to decide when it wants to re-start. It idles low and giving it a light tap of the gas peddle actually makes it worse. Truck also will die if taking a hard right turn.
I was told that it might be the cam or crankshaft sensor...or the whole computer. Who has an opinion or experience with this sort of issue?
Thank you very much!
Old Mar 3, 2009 | 05:28 PM
95_318SLT's Avatar
95_318SLT
Can you give a little more info about your truck, like what engine/drivetrain combo is in it.
The first things that come to my mind are a faulty IAC (Idle Air Controller) or MAP sensor.
Old Mar 4, 2009 | 12:35 PM
primered92dakota
It is a V8 with an automatic. All original mileage at 90k...um...what else do you need to know?
Thank you.
Old Mar 5, 2009 | 07:39 AM
crazy's Avatar
crazy
Default codes
have you checked if there are any codes stored in the computer??may start ya in the right direction,,some problems don't show up in just a code scan ,,but this may help ya some if you never did it before,,http://www.wonderhowto.com/how-to/vi...ehicle-251793/ ,,also if you do get a code this site also has some good videos on testing sensors and relays,,might save ya some money and guesswork..
crazy
