Section Moderator
Quote:
If it's pouring back out the fill hole, it's probably full. How much are you trying to put in it? They don't really hold much.Originally Posted by chrislipscomb28
I have a 92 dodge 4x4 trying to find easy way tto fill without haveing to remove it. Tried to put a hose on trans oil bottle to make ease of filling but it just wants to pour back out the fill orfice any help would be great
Quote:
Harbor freight sells a nice little fluid pump for under $5. I used one when I replaced the seals and gaskets on my front differential the gasket on my rear axle. Also good for brake fluid on a motorhome. The seals on the pump tend to die quickly, but the little pumps are so cheap they're disposable. Get some nitrile gloves, tooOriginally Posted by chrislipscomb28
Quote:
if it's pouring out of the upper fill opening (which is to the right of and about an inch above the drain plug) then the T-case is full.Originally Posted by chrislipscomb28
