first 4wd clutch repair(help)PLEASE
Old Mar 19, 2009 | 07:55 PM
jim holden's Avatar
jim holden
Question first 4wd clutch repair(help)PLEASE
hav a 94 4wd w/318 lookin for any help/tips any one has-done clutchs b4 but this has double the stuff to undo/take off could really use help to get started and what to watch out for
Old Mar 19, 2009 | 09:18 PM
95_318SLT's Avatar
95_318SLT
Start by removing the front and rear driveshafts. Next, unplug everything from and unbolt the transfer case and set it to the side. Next, remove the bracket on both sides that is bolted to the bellhousing, engine, and front axle. Next, remove the starter, then remove the dust sheild. Next, remove the two shifters sticking through the floor, remove the slave cylinder (don't remove the lines from the slave cylinder, its a sealed system that not supposed to be bleedable...it can be bled but its a PITA), and remove all the wires connected to the transmission. Next, support the transmission with a jack and remove the engine block to bellhousing bolts. Slide the transmission away and replace clutch like normal. I think that was about it.
Old Mar 19, 2009 | 10:15 PM
jim holden's Avatar
jim holden
Talking make it sound easy
thanks for the break down -the chilton book had me lookin all over the frickin place and removin more than that -plus never actually told me what to start with-so will let ya know how it goes on monday
Old Mar 19, 2009 | 10:16 PM
jim holden's Avatar
jim holden
will be back here
thanks guys
Old Mar 19, 2009 | 10:20 PM
95_318SLT's Avatar
95_318SLT
If your chilton book isn't doing you any good, we have the links on this forum for the full factory service manuals (I don't think the '94 is there, but it should be close enough to a '95)...
https://dodgeforum.com/forum/1st-gen...ce-manual.html
That manual gave me all the info I needed when I did my automatic to manual transmission swap a couple weeks ago.
Old Mar 19, 2009 | 11:00 PM
jdog's Avatar
jdog
don't forget to unhook the battery
Old Mar 19, 2009 | 11:04 PM
95_318SLT's Avatar
95_318SLT
LOL, how did I forget that one!! Don't put a wrench near your starter until your battery is unhooked! It throws a very impressive spark if you accidentally ground it out with a wrench.
Old Mar 20, 2009 | 12:34 AM
95_318SLT's Avatar
95_318SLT
I knew I was forgetting one more thing... You may have to remove the Y-pipe to get it out of the way of the bellhousing.
Also, all of the bolts are much easier to get to if you unbolt and remove the inner fender wells.
Old Mar 20, 2009 | 03:21 AM
jim holden's Avatar
jim holden
thanks for all the info guys appreciate it -already done the forget to unhook battery along time ago and yes it is a cool blue spark lol
will let you know how everything went monday been along time since i crawled underneath my truck-should be fun
agian thanks for all the help-
Old Mar 22, 2009 | 08:41 PM
gr95dak's Avatar
gr95dak
Default clutch replacement
It appears that others are giving you good advice. However, pay particular attention to the replacement clutch you will be installing. I replaced mine about 5K miles ago with a well-known aftermarket unit and now the vehicle shakes when reversing. It works OK in all forward gears. Look particularly at the thickness of the clutch disc of your replacement unit. And, while you're at it, you might also think about a new pilot bearing......... Just a few suggestions.
