compression ratio?gasket thickness
Old Mar 24, 2009 | 03:03 PM
my91dakota207's Avatar
my91dakota207
Default compression ratio?gasket thickness
have a 91 dakota 5.2,wanted to know what the stock comp. ratio was and if it can be raised to around 9.5.1 by just the gasket or if the head would have to be shaved.
Old Mar 24, 2009 | 03:56 PM
95_318SLT's Avatar
95_318SLT
I believe the '91 is 9.2:1. I'm not sure about the gasket.
Old Mar 25, 2009 | 12:03 PM
Crazy4x4RT's Avatar
Crazy4x4RT
My stock stlye head gasket was .030 in. They sell .010 wich will raie it but not buy not by much. you can deck down heads and block around .020 or so each. this will raise more maybe .1 or so. You can google it and find the calclators that will tell you.
