difference between 91 5.2 roller cam and r/t 5.8 roller cam?
Old Mar 24, 2009 | 06:35 PM
my91dakota207's Avatar
my91dakota207
Default difference between 91 5.2 roller cam and r/t 5.8 roller cam?
will a dakota r/t 5.8 roller cam fit in my 91 5.2?
Old Mar 24, 2009 | 07:21 PM
95_318SLT's Avatar
95_318SLT
I'm not sure, but I'm leaning toward no. The magnum and LA engines have different oiling systems and different heads. I think the lower rotating assembly is all that can be interchanged. Just out of curiosity, why would you want to put a factory cam back in your truck? If you're going to spend the time and money, why not put a performance cam in it?
Old Mar 24, 2009 | 07:24 PM
my91dakota207
was thinking about this cam but not sure yet.I want the rough idle,was looking at the ***** thumpa but is said was retro fit.
http://store.summitracing.com/partde...9&autoview=sku
Old Mar 24, 2009 | 07:28 PM
95_318SLT's Avatar
95_318SLT
That would be a sweet cam! I wish I could tell you if it fit or not, but I will advise you to call Comp cams and ask them, they have great customer support. It does say its for a '91 360, and the 318 blocks and 360 blocks are identical except for the bore, so it might work!
Old Mar 24, 2009 | 07:31 PM
my91dakota207
the cam I was thinking about or the ***** thumpa?I dont know how much lift the stock heads and springs can handle
Old Mar 24, 2009 | 08:55 PM
95_318SLT's Avatar
95_318SLT
The one you gave the link to. The stock heads can handle its lift, but you'll probably need new springs.
