questions about magnums????
Old Mar 25, 2009 | 06:03 PM
my91dakota207's Avatar
my91dakota207
Default questions about magnums????
I have a 91 dakota 5.2,what would I have to do to swap in a 5.8 magnum motor?
what are the differences in the 91 5.2 and the 5.2 or 5.8 magnum?
would magnum heads fit on a non-magnum motor?
would a magnum intake fit on non-magnum heads?
would my same computer and wiring harness in my 91 work with a 5.8 magnum?
Old Mar 25, 2009 | 06:34 PM
miniderblank's Avatar
miniderblank
I thought the swap was to a 5.9 But there is a whole FAQ section about this
Old Mar 25, 2009 | 06:36 PM
my91dakota207
yes it is a 5.9
Old Mar 25, 2009 | 07:26 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Almost everything is the same from LA blocks to magnum blocks. The motor mount location are the same. Some LA's were different tho. The head bolt pattern is the same. I think just need to drill a oil hole. The intakes are different. So you can use a magnum long block and use your heads and a intake. For all the details check out the FAQ2 and Allpar.com will give you the differences in between them.
