pushrod/valve clearance
Old Apr 14, 2009 | 06:11 PM
black90dak's Avatar
black90dak
Default pushrod/valve clearance
does anyone know what the valve clearance is on a stock 1990 v6 3.9. i know the stock length of the pushrods are 6.740 and what i was wondering how much clearance was there b/c i want to go with a longer pushrod instead of going with roller rock change much cheaper this way. the pushrods from a 92 v6 3.9 are 6.900 in length. any info will help. also the cam from a 92 has a bigger lift than the 90 would there be a clearance issue if i leave the stock pushrods and go with this cam or even better with the longer pushrods and this cam..again any info will help
Old Apr 14, 2009 | 06:17 PM
95_318SLT's Avatar
95_318SLT
This link is copied from the FAQs section...
http://dodgeram.org/tech/gas/specs/index.html
Check that site and see if it tell you what you need to know. I know it has that info for the 5.2, which near identical to the is a 3.9 but with 2 more cylinders.
