What to buy?
Old Apr 12, 2009 | 06:39 PM
ModT's Avatar
ModT
Default What to buy?
So my boyfriend was lookin at my truck and he was underneath and was pickin out all the **** that was wrong with it, so he said that the sealant on the diffs are leaking. Well just "sweating" how should i go about doing something about that?
And The shock on the right side is broken so Im gonna swap all of them I was just wondering what shocks you would recommend?
And how would I go about doing this on my own with maybe 1 helper?
Old Apr 12, 2009 | 06:55 PM
dhvaughan's Avatar
dhvaughan
well is your boyfriend any good with a wrench ? buy him the parts and tell him to get busy.
assuming your diff cover is what's leaking, its an easy service. just use black RTV as a gasket sealer. when removing the cover, use a thin 1-2" wide putty knive to avoid bending the cover. don't lose the magnet inside, and don't over tighten the little cover bolts. if its your pinion seal its a little more more.
i think shocks are overrated. i just use cheap monroe or gabriel truck shock from whereever they are cheapest.
haynes manual, basic tools, a floor jack or two, drain pan...
edit... i meant to post this while ago.
http://www.pavementsucks.com/tech/diff.php
Old Apr 12, 2009 | 07:17 PM
95_318SLT's Avatar
95_318SLT
+1 on that. None of what you mentioned is hard at all! Besides, you have us to guide you through it :P
A tube of gasket sealant is all you need for the diff covers... $5-6 and about 20 minutes to fix it. Like said above DO NOT OVERTIGHTEN those bolts... I snapped the head off one of mine with my impact :/ (I'll get a bolt extracting set next time I have to mess with it)
For the shocks, you can get away with about $150-200 for all 4 and depending on how hard the bolts are to get out (mine were a PITA), about 1-2 hours to swap them. I have Monroe Sensa-Trac towing shocks on the back and front of my truck. The rears have a coil "helper" spring around them and they work great!
All the work you mentioned shouldn't take more than a saturday afternoon (unless like said above, theres something worse wrong).
Old Apr 12, 2009 | 07:18 PM
dodgerules86's Avatar
dodgerules86
I used the Monroe Sensa-Track shocks, and, well, I've only got about 15,000 miles or so on them, and they have no rebound left in them, their done.
But, basically what dhvaughan said.
Your boyfriend, perhaps with a little help from you, should be able to knock it out easily.
Old Apr 12, 2009 | 07:21 PM
95_318SLT's Avatar
95_318SLT
LOL, we must have been typing at the same time :P
My sensa trac shocks have about 15,000 miles on them right now and they still work great! The only job of the shock is to stop the spring from bouncing.
Old Apr 12, 2009 | 07:55 PM
dodgerules86
Well, mine no longer function right.
When I put them on the truck, it was difficult to compress the shock to get the holes to line up.
But now, with the shock fully compressed, it doesn't uncompress on its own.
Oh well, I was gonna replace all the shocks anyways.
Old Apr 12, 2009 | 08:12 PM
95_318SLT's Avatar
95_318SLT
Yeah, lol, I know what you mean about trying to compress them. I had to use my floor jack to compress the shocks to get them on. Do your's have the coil "helper" spring on them or is it just a shock? I hope mine aren't about to go! I have too many other projects going on with that truck.
Old Apr 12, 2009 | 09:00 PM
dodgerules86
No coil helper spring on mine. I have no idea what those look like, but mine is just a shock.
Old Apr 12, 2009 | 09:12 PM
95_318SLT's Avatar
95_318SLT
These.... The spring is supposed to help support like 1200 more lbs of hauling capacity (not to mention it helps the shock rebound!)
Old Apr 12, 2009 | 09:30 PM
dodgerules86
Hmmm, interesting. Yea, I've never seen them before. Do people sell 'em for the Dakota?
