'95 dakota 2.5L
Old Apr 17, 2009 | 06:15 PM
burch767's Avatar
burch767
Default '95 dakota 2.5L
help...my engine starts up, revs. high for a few seconds, then idles for a few seconds, then sputters, revs high sputters, goes on like that for a few mins. then dies. i can start it up and goes through same motions. i have already replaced the map sensor, iac, and basic tune up. anybody have any sugestions.
Old Apr 17, 2009 | 07:13 PM
95_318SLT's Avatar
95_318SLT
This should be in the 1st gen section...
Sounds to me like the IAC, its at the back of the throttle body and controls the air flow at idle. Its about $40 to replace it and just as easy to replace as the MAP sensor.
Old Apr 17, 2009 | 09:19 PM
95_318SLT's Avatar
95_318SLT
Lol, I didn't notice you already said you replaced the IAC. When you replaced the parts on that list, did you reset the computer? Also after you reset the computer you need to drive it at highway speeds for about 20 minutes so the computer can "re-learn" the truck. When I replaced my IAC, it took the truck a minute to know what to do with it, it won't run right immediatley.
Old Apr 22, 2009 | 03:29 PM
burch767's Avatar
burch767
drove the truck for half hour, not only is it still acting the same, but now it doesnt have any power when i give it gas.
Old Apr 30, 2009 | 04:48 PM
burch767's Avatar
burch767
replaced a couple of vac lines that were split idles better but still reves high when given gas and holds high idle for a few seconds then slowly goes back to idle. sprayed carb cleaner over throttle body and all vac lines did not find any leaks.
Old Nov 11, 2009 | 06:11 PM
burch767's Avatar
burch767
just got done rebuilding engine, almost everything is running normal, accept throwing code 24 as soon as i start engine. replaced tps, still throwing code 24, replaced comp. and still same code. tried tracing wires and could not find any shorts with every thing unplugged. when i plug map back in shows short. has any body come across this, and if so how do i fix.
Old Mar 7, 2012 | 05:17 PM
burch767's Avatar
burch767
Had truck running good for a wile. Now doing exactly what it was doing before replaced computer. Any ideas why computer keeps burning out in tps circuit.
