Tearing into my 318... gonna need advice!!
Old Jun 24, 2009 | 11:59 PM
  #51
dbilik's Avatar
dbilik
That's awesome. Good job on that one.
Old Jun 26, 2009 | 12:23 AM
  #52
Bump's Avatar
Bump
One more thing... and this was a pre existing condition pre motor swap... If the truck sits for more than an hour, it will lose fuel pressure. When I go to start it, it will crank for 8 to 10 seconds before will start, with or with out cycling the ignition to prime the pump.
once the motor is running, there dosent seem to be any fuel pressure issues and when its shut off and then re-started with in 15 - 30 minutes or so, it will fire right up.
Everything came in new with the new motor (regulator, rails, injectors, etc) and I thought it might fix it, but it didnt. same issue. truck runs great, but cranks a while before it will start cold.
Fuel pump? return line?
Old Jun 26, 2009 | 01:57 AM
  #53
dbilik's Avatar
dbilik
You have a return line on the V8? Stock? My V6 has a return line but I was prepared to not have one when I complete my swap. Maybe somone with a V8 here can help clarify for me.
Old Jun 26, 2009 | 03:22 PM
  #54
Bump's Avatar
Bump
I am not sure if there is a return line. Just something that came to mind. I'll have to look.
Old Jun 26, 2009 | 07:13 PM
  #55
dbilik's Avatar
dbilik
I want to say you don't have it on a 318, only on the V6.
Old Jun 26, 2009 | 07:34 PM
  #56
Bump's Avatar
Bump
So it losing pressure back in to the tank from the motor would only be due to a failing fuel pump?
