1995 Dodge Dakato V6
Old May 2, 2009 | 12:16 PM
maxwell18's Avatar
maxwell18
Default 1995 Dodge Dakato V6
I'm new to forum and need some help. I just purchased a 1995 Dakato V6 with 39K miles overall great shape. It has not been serviced for a long if any at all. I have got everything changed fluids. It idles real ruff at idle but runs real good all the way up from idle. When i turn on the A/C the rpm does not increase so I just purchased a idle speed controla and will put it on today. Any ideas what will cause this idle problem? What rpm should it idle at?
Thanks
Old May 17, 2009 | 03:24 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You can try doing a tune up. Spark plugs, wires, cap and rotor. You could post in the 1st gen dakota section and got more results.
Old May 17, 2009 | 04:01 AM
dodgerules86's Avatar
dodgerules86
I've taken the liberty to move it.
As Crazy said, try a tune up changing the things he said. That should really help out.
Pay attention to the condition of the plugs when you pull them out. Note if one, or a few, plugs look worse than others.
