4x4 issues
could broke the axle or something in the tube. Not sure yet. I recall the last time i went muddin a clicking/banging noise , but i just thought it was going to be time for ANOTHER t-case.....hoping to get into it this weekend..
Yup... pulled the cover today. **** all over. axle clips. a cone washer, 2 spider gears( not the axle ends) and the big pin that holds the spiders together is snapped into 3 pieces...
hoping to get parts for it, what are the chances?
Chad
Chad
You can pretty much get everything from http://www.ringpinion.com/ . Or dealer. But for everything you need it may be best to go to your local junkyard and get a complete front diff.
I was just looking through they're parts and they see mto have everything you may need so i was wondering? Since im probably going to stoke my engine. With the increase in power should i upgrade my 8.25" or try and find a 9.25" for the rear? Keep in mind its an 89 so i dont know what rear 9.25" will bolt into my truck? Also it is 2WD if i keep the 8.25 i want to change the gears to 3.90 and maybe to positrack? What do you think?
I was hoping the 8.25 could handle it. I just want to change the gears and do limited slip. What one do you think i should go with i was thinking this one.
http://www.ringpinion.com/PartsList....b-Differential
either the AG 542072-HP or the PT 1230
What do you think?
I would like to do this TT 912A553 but i need 29 spline, which i cant remember where but you can put 29 spline axels in the older diffs with 27 spline. right?
What do you think?
Ya you can swap axle shafts. But do you want a LSD or a full locker? A posi, possitrack or LSD, limited slip differential allow some slip. So you will get better traction then you do now but not 100% of traction that you could be getting. A full locker will give you 100%. A LSD is better on the streets, then an automatic locker. But a selectable locker like the arb unit will let you turn it off for street use and on for 100% traction offroad or at the drag strip. And it also deepens on the price.
