got some codes from my truck....
well as you all know, i just recently installed the hughes plenum plate fix, and now i find the truck is running a bit better. HOWEVER, i did a code test on it just now, and it came up with these codes....
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
now, what im wondering is, what exactly does it mean? is this a cause of the intake fix and now these sensors are so wacked that they cant adjust? or should i try resetting the computer while i do the oil change and see if that fixes it? i just dont really understand what it means by out of range..
i reset the computer, those codes still come up. but i still dont get what it means by out of range... weirdest part is those sensors arent acting up at all, the truck is running fine, responds fine, not overheating... (assuming that i have the correct understanding of what these sensors actually do...)
