Transmission mount replacement
Old May 19, 2009 | 01:37 AM
dbilik's Avatar
dbilik
Default Transmission mount replacement
When I swap out my transmission I would like to replace the transmission mount also. Anyone know where to get one and if they even make replacements? I checked the parts guide and it is on page 9D-1050D, but I checked some online parts places and I am having no luck. Thanks.
Old May 19, 2009 | 02:19 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm guessing its an auto. Looks like manual trannys don't have a replacement mount just bushings. The page you listed is not the correct page. You need to look at 9B-1030 part number for auto 5205 8474
www.autozone.com www.napaonline.com Most autoparts stores.
http://www.autozone.com/autozone/cat...ll&totalPages=[I@808517&currentPage=1&vehicleNValue=&navValue=112 00166&parentId=cat10001&fromString=search&fromWher e=null&filterByKeyWord=mount&categoryNValue=112999 99&categoryDisplayName=Drivetrain&_requestid=45889 2
Old May 19, 2009 | 09:44 AM
dbilik's Avatar
dbilik
It will be for a manual. I might just have to wait until I pull the AX-15 and then order or find something that will work before I install the NV4500. The NV4500 is much heavier so I just wanted to make sure I replaced the bushings or mount before I installed the new tranny. Thanks.
Old Mar 15, 2010 | 03:44 AM
j306's Avatar
j306
I have concern with my tranny mount too.
I have an auto tranny though.
Should there be 1/8" of play between the rubber
and the tranny plate?
Old Mar 15, 2010 | 07:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No there should be no play in between. But the rubber does flex. So if you truly have play and not flex then you need to replace the mount. Also don't be scared to start a new thread instead of pulling up an old one.
Old Mar 16, 2010 | 03:42 AM
j306's Avatar
j306
Ok cool, just thought I would ask a question on this thread.
No need to start a new thread when this topic suits perfect.
Question answered....thank you!
