92 Dakota-lifter
Old May 24, 2009 | 12:21 PM
barra340's Avatar
barra340
Default 92 Dakota-lifter
Any issues with lifters in the early motors?, 5.2. I have one just making noise and someone was telling me they made different ones later to fix the issue.
Old May 24, 2009 | 10:57 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Nothing I know of. Lifters usually fail due to oil issues. Not enough oil, not the right weight. Dirty oil.
Old May 25, 2009 | 09:00 PM
injmopar's Avatar
injmopar
Too many short drives .If you don't run the engine at full temp long enough .Sludge and varnish builds up in the engine .Varnish screws up the metering of oil to the lifter . Switch to synthetic and add EOS (engine oil suppliment ) .It's a GM product that has zinc in it .
Old May 26, 2009 | 10:37 AM
barra340's Avatar
barra340
I have been doing some short driving. I did a good cleaning of the engine with that seafoam product and have been giving it oil changes at 5k. I think I will change the oil and then take the valve covers off to see which lifter on the pass side is not pumping up. I should probably just get the heads done while I am at it and pull those.
Old May 31, 2009 | 12:00 PM
barra340's Avatar
barra340
Well I pulled it apart. I checked oil pressure with a mechanical guage and it was good pressure. The one lifter would not pump up at all so replaced them. Heads looked good, radiator is toast from the looks of it! Going to replace the cam while I am at it and get the heads redone.
Old May 31, 2009 | 02:27 PM
95_318SLT's Avatar
95_318SLT
If your putting in a performance cam, make sure to get new valve springs.
