Tearing down 318
Old May 29, 2009 | 11:40 AM
dbilik's Avatar
dbilik
Thumbs up Tearing down 318
I am about halfway dismantled. Just wanted to post some pictures as I go along. I am in the process of cleaning stuff now as I take it out. Really happy with how clean it is inside.
318 on the stand...
After I got down to the heads...
Maybe I finally figured out the code to get the pictures in??
Old May 29, 2009 | 12:47 PM
Crazy4x4RT's Avatar
Crazy4x4RT
When your on the flicker page with the picture you want. Right button click on the picture. Go to properties. Highlight the address (URL) and copy it. Right click and go to copy. Or you can right button click on the address and go to select all. Then copy. On the post section click the icon that looks like a picture. Then paste it in the small popup.
Old May 30, 2009 | 09:56 PM
Bump's Avatar
Bump
Yuck... reminds me of whats sitting in my driveway. I an in the middle of a 318 replacment and SOOOOOOO burned out on that project!
good luck man... Keep the pics coming.
Old May 31, 2009 | 02:07 AM
dbilik's Avatar
dbilik
Time for updates. I have come a long way today.
Removed the heads and prepped the block...
Primed...3 coats
Painted...3-4 coats
Untaped...
Replaced rear main seals, timing chain cover gasket, front crankshaft seal, painted oil pan, painted all the heads and intake manifold...I am sure I did some other stuff too. Also really glad I did the seal replacements, found a blown plenum in the process. Woudl have been pretty pissed if I had finished it all only to have to replace the plenum in the truck.
A good picture I think showing what a bad plenum looks like. I ordered my aluminum plenum plate from Hughes today. At 48,000 miles this happened pretty fast. My brothers truck had it go out at 35,000 on his 318.
dbilik's Avatar
dbilik
Thank Crazy, I finally got it. Pictures are so nice to have.
Here is where I called it quits for the night...
Old May 31, 2009 | 02:12 AM
dbilik's Avatar
dbilik
Anyone got any hints on replacing the dampener? I am going to go to autozone tommorrow and look for the replacement tool, but they haven't been much help. I couldn't find the tool to install the front crankshaft oil seal either so I fabricated one out of wood and used the original bolt to pull it into the timing chain cover. Now I need the installer for the dampener. It will need to have the same thread as the bolt that holds the main pulley and dampener in. ALmost like a hub installer tool.
Old May 31, 2009 | 10:56 AM
Dakota1089's Avatar
Dakota1089
I couldnt help you with that but might i say nice job so far looks good. cant wait to start that on my mag.
Old May 31, 2009 | 12:04 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Looks good. Good job on the paint and the posting the pics! Can't wait to see it in the truck.
Old May 31, 2009 | 02:09 PM
pashadowops's Avatar
pashadowops
Looks really nice in those colors. I think I missed the very beginning of this endeavor you started. Is this an engine swap, was there something wrong with the engine that caused you to pull it, or did you pull it just to clean it up? I want to do my engine but, I'm waiting til something really goes bad on it so I can justify pulling it to rebuild.
BTW...I must compliment you on cleanliness of your shop. I think perhaps if I kept my garage that clean and organized I might not mind working on my vehicles again...hehe
Old Jun 1, 2009 | 12:06 AM
dbilik's Avatar
dbilik
The beggining was posted a few weeks back when I got stuck in Minnesota with a blown head gasket. Towed the truck home, and did the repair, put the V6 back together and a lifter went at some point also that I didn't know about. Anyways, it needs a valve job and if you are going to do that might as well rebuild it and pull it, SO...that leads me to this.
I tracked down a 318 with 48,000 or so miles on it and a tranny from a 2WD 1997 Dakota. I am swapping it into my truck, but since mine is a 4WD I needed a 4WD tranny, so instead of messing with a good NV3500 trans, I went out and got a used NV4500HD trans.
Before I put anything back into the truck it is getting cleaned, getting new gaskets, and getting minor upgrades. Hopefully it will all pay off in the end.
