93 Dakota Refrigerant Refill?
Old Jun 6, 2009 | 09:22 PM
Senate427's Avatar
Senate427
Default 93 Dakota Refrigerant Refill?
I own a 1993 Dakota V6 engine and about 165,000 miles on it. I think my A/C needs a refrigerant refill because all it blows out is warm air. Last year I did a lot of work on my vacuum hoses and cleaned out all the vents and hoses so I know that nothing else could be the blame.
So what I need to know is how do I refill my A/C with refrigerant. I have a Haynes manual that has directions but I need better instructions. I saw the big cans of 135a refrigerant at my local auto store so I know I can legally buy it.
Please Help
Thanks
Old Jun 6, 2009 | 09:32 PM
dodgerules86's Avatar
dodgerules86
R-134a was used on 1994+ Dakotas. Yours uses R-12 unless a conversion has been done.
The stem to charge the system is different for R-12 and R-134a systems.
You always charge the A/C system on the low side, which is on the passenger side fenderwall.
Old Jun 6, 2009 | 09:40 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You will need to covert the AC system if it is R-12. You can do it yourself if you have a vacuum pump. And get the pieces in a kit like this one. http://www.autozone.com/autozone/cat...questid=293220
Or take it to a quality shop and have them do it. With a shop it can be pricey. But it will be done right with the correct amount of Freon and the right amount of oil.
Old Jun 6, 2009 | 09:44 PM
dodgerules86
Yea, it's important to get the right amount of refrigerant and oil. I replaced my compressor and I think I used too much oil = not a lot of cold air.
Old Jun 6, 2009 | 11:51 PM
dbilik's Avatar
dbilik
Yep, I added refrigerant and it had oil in it, ended up with too much oil. Haven't bought a vacuum yet to fix it myself. I have a small leak somewhere that I will have to pull the UV dye out for.
Old Jun 7, 2009 | 09:20 AM
kahanabob's Avatar
kahanabob
My 90 had the same issue and I had it filled with the old R-12 at a auto A/C shop not long ago..
