no spark
Old Jun 10, 2009 | 05:48 PM
dakota_freak1989's Avatar
dakota_freak1989
Default no spark
hello i have a 1990 dodge dakota 2wd lt 4.7l and i cant get any spark out of the coil ive replaced the cap and rotor before i thought it was the coil so thats not the problem it gets power but dose not do anything
any help would be greatley apritiated
Old Jun 10, 2009 | 07:41 PM
dakota_freak1989
i even replaced the coil but still have no spark i tested with a light tester if it had a pos and a neg going to it when i turn the key and wound up finding it has 2 positives im stumped did a wire fry? is a relay poped or what would do this ive tryed putting a negitive wire on the - side and left one + on the other but still get no spark i dont know what would do it so any help for a newb at this would be greatfull
Old Jun 11, 2009 | 01:56 AM
Crazy4x4RT's Avatar
Crazy4x4RT
In 89 there were no 4.7l. Just 3.9 v6 and 2.5 4cly. Or if your lucky 5.2 V8 in the shelbys only. Unless its is was swapped in. To me your problem sounds like the computer is not putting out the signal to the coil. It may be from a failed sensor or wires to power the comp. Or wires from the comp to the coil. Tons of possibilities! The only way to know for sure is for you to check all wires.
Old Jun 11, 2009 | 10:40 AM
dakota_freak1989
aright ill check all the wires tonight and see if anything is mesed up or fried
Old Jun 12, 2009 | 01:20 PM
dakota_freak1989
got the spark working now but got new problems lol trying to resurect my dads old dakota seems to be quite the challenge now when i start it it runs for a second or two and shuts off
