OBD I to OBD II conversion...
Old Jun 18, 2009 | 01:58 PM
RockGuardedDak's Avatar
RockGuardedDak
Default OBD I to OBD II conversion...
well as you guys may remember, i got myself a 318 that im building a 390 out of. the 318 is a '97, so that being said, im gunna get a '97 tranny for it too. how hard is it really to convert my truck from OBD I to OBD II? i really want the functionality of an OBD II computer, that way i can set the engine up for daily driving, or the track, with one of those tuners.
Old Jun 18, 2009 | 05:08 PM
dbilik's Avatar
dbilik
I was talking to a Dodge guy about this very topic. I was told that it is very doable if you can track down the new wiring harness and the PCM for your engine. Granted it is some work but I don't think it is any worse than anythign else you are doing.
Which '97 tranny you looking at? That would be the only thing I can see being an issue. Is the '97 electronically controlled or hydraulically?
Old Jun 18, 2009 | 07:21 PM
skyshark186's Avatar
skyshark186
97 should be electric
Old Jun 18, 2009 | 09:43 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it is possible. Tons of work. Entire wiring harness. Not just from the engine bay but from the interior, too. Anything like abs system, to air bag systems. I don't know for sure but most of that all is controlled by one computer. And if it senses a failer it will give you a check engine light and will not run it's full potential. And I'm not to sure but I can bet there is no turner for any pre 2000 year obd2 dodge. I may be wrong. But Dodge is not as popular as Chevy and ford and the aftermarket never picked it up.
If your dead set on OBD2 I would say get an aftermarket system. Most of them come complete with a computer to PC hook up. It is expensive. But after buying all the necessary parts and all for a stock system it will pretty much equal. Price.
Don't get me wrong I would defiantly prefer OBD2, but it is to much work for a few extra HP if you can get it all for it. Especially since your truck is already OBD1 equipped. We do have the link in the FAQ2 for a hand held unit to configure OBD1 systems.
And I may be wrong but I think when Bad96 did his swap, all he needed to do for wires is add in the 2 injector wiring. The link is in the FAQ2.
