almost outta daylight need answer quick lolz....!!!!
Old Jul 3, 2009 | 08:04 PM
xxxxrhodesxxxx's Avatar
xxxxrhodesxxxx
Default almost outta daylight need answer quick lolz....!!!!
wat is the torque pressure on a intake manifold i forget.....i just cleaned my motor out and this is the last thing i have to do before im done thanx folks....
Old Jul 3, 2009 | 08:49 PM
95_318SLT's Avatar
95_318SLT
Which engine? You don't just tighten the bolts, there is a specific procedure you have to follow that is different for each engine.
Old Jul 3, 2009 | 08:52 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya it would help if you said what motor. Next time if your in a hurry and don't have time to wait for others to find the answer. You can always go to the FAQ in this section. We have several online service manuals. That will save you hours waiting for a response from one of us.
Old Jul 3, 2009 | 08:54 PM
xxxxrhodesxxxx
sorry 318 mag... aint it 35 ft lbs
Old Jul 3, 2009 | 09:02 PM
95_318SLT's Avatar
95_318SLT
This is copied from the FSM...
3.9L ENGINE
Step 1 - Tighten bolts 1 and 2 to 8 N m (72 in. lbs.) torque. Tighten in alternating steps of 1.4 N m (12 in.lbs.) torque at a time.
39.jpg?t=1246669295
Step 2 - Tighten bolts 3 thru 12, in sequence, to 8 N m (72 in. lbs.) torque.
Step 3 - Check that all bolts are tightened to 8 N m (72 in. lbs.) torque.
Step 4 - Tighten all bolts, in sequence, to 16 N m (12 ft. lbs.) torque.
Step 5 - Check that all bolts are tightened to 16 Nm (12 ft. lbs.) torque.
5.2L ENGINE
Step 1 - Tighten bolts 1 thru 4, in sequence, to 8 N m (72 in. lbs.) torque. Tighten in alternating steps of 1.4 N m (12 in. lbs.) torque at a time.
Step 2 - Tighten bolts 5 thru 12, in sequence, to 8 N m (72 in. lbs.) torque.
Step 5 - Check that all bolts are tightened to 16 N m (12 ft. lbs.) torque.
Old Jul 3, 2009 | 09:40 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Also on the Magnum engines the torque for the intake bolts is cast into it.
Old Jul 3, 2009 | 11:16 PM
dbilik's Avatar
dbilik
I didn't know that.
Old Jul 4, 2009 | 02:05 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya also with the cylinder number and ignition timing order.
Old Jul 4, 2009 | 12:38 PM
RockGuardedDak's Avatar
RockGuardedDak
i was wondering if you guys had the torque specifications for the plenum on the 3.9? i was looking for it on the FAQ but couldnt find anything that told me. i have a strange feeling that my mechanic installed the hughes plenum fix wrong. or at least he didnt torque it properly... i sure hope not tho, otherwise shes gunna just keep burning oil since i already have to get a new starter and dont have the money for it as it is...
Old Jul 4, 2009 | 01:11 PM
Crazy4x4RT's Avatar
Crazy4x4RT
In the FAQ go to the Service "Manual section", there you can download 2 service manuals. Also 2 or 3 online manuals. In the 95 service manual that you can download go to section 11. page 9.
