rusty shocks
on
Use penetrating oil. Tap the top of the nut with a mallet and let it sit overnight (or at least for like 10 minutes or so)
Also, (since I try to not make assumptions), you should heat the nut until it is a dim red. (In case you don't know)
If none of that works, looks like you will have to be "creative" with something that cuts.
