Things to do while tranny/axle out
Old Aug 14, 2009 | 01:54 PM
skyshark186's Avatar
skyshark186
Default Things to do while tranny/axle out
Oil pan gasket is definitely one. Anything else I should be working on in the interum of trying to find a 5 speed? I would rather not pull this motor, although there aint much left attached at this point.
I have the spare motor from my other truck if I decide I want to do anything fancy.....but Im probably gonna sell it. Why waste a bunch of money to upgrade this one when I could just buy a 360 anyway? Honestly Ill probably regear before I go nuts on the motor. Im planning on running 35's or 37s.....depending on how I feel when I get my sas done.
Thoughts? This is a budget build, but that doesnt mean I want to neglect maintenance, especially while its as easy as its ever gonna get.
Old Aug 14, 2009 | 02:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Just remember it's all the small things. So clean up the frame. Paint to prevent rust. Is your oil pan gasket leaking?
Old Aug 14, 2009 | 03:48 PM
skyshark186
No its not. But it seems like it would be worth it to change it while I have all this crap out rather than to have to pull it again to do a 30 dollar gasket.
I was thinking about spraying some sort of undercoating on it while Im messing around. Suppose Ill stop being lazy and do it. My frame already has a fair amount of rust, so Im half afraid Ill grind into something I dont wanna find.
Old Aug 14, 2009 | 04:25 PM
ZackN920's Avatar
ZackN920
Since you have your title of the thread being Things to do while tranny/axle out id say add either a limited slip system or locker system in your axle
Old Aug 14, 2009 | 04:32 PM
skyshark186
Lol....how bout swap it out with a dana 44?
I guess I should clarify. Things to do to the motor while the transmission and axle are out. Anything that is easier to axcess without them in there.
Old Aug 16, 2009 | 12:00 PM
woodbutcher5691's Avatar
woodbutcher5691
Maybe a new rear crank seal?
Old Aug 16, 2009 | 02:18 PM
skyshark186
yeah....Ill look at that too butcher.
My motor mounts are still good so Im not worried about that.
