'94 front end alignment question
Dodge Dakota 6 cyl. 2 wheel drive.
There is a rod about 10" long inside the hood on each side of the motor and runs front to back and has something to do with the alignment. The rubber is bad. I got two nuts off the the two bolts pointing upward on one rod.
How do they come off after that if I get all the nuts off? I'm thinking only 3 are necessary.
I won't be able to do the alignment, so would I be better off having a mechanic do the whole thing?
Thanks.
Thanks.
