Nice find.
Old Aug 31, 2009 | 02:06 PM
dbilik's Avatar
dbilik
Can't he just bring an angle grinder and cut the U-bolts, unhook the shock, driveshaft, and brake lines and he should be good. Or am I missing something here? This is assuming the guy is going to let him take the whole rear axle.
Not sure how different the posi is from the LSD, but I removed the limited slip out of a rear axle in about 20 minutes. Installing it will take much longer but I am not in a hurry. I will probably take it somewhere and let somone else set it.
Old Aug 31, 2009 | 02:35 PM
Crazy4x4RT's Avatar
Crazy4x4RT
A LSD is a Posi. And I agree it wont take long. Just remove the cover then the crosspin/ c-clips. Slide out axles. Remove the 4 bearing Carrier bolts. Adjust down the side adjusters. And done!
Old Aug 31, 2009 | 02:55 PM
skyshark186's Avatar
skyshark186
Lol. Yes thats true its not a super hard process. But if youve never even looked at the guts of an axle before its not a 30 minute job. Especially not if the guy still wants the thing to roll when hes done with it.
Old Aug 31, 2009 | 03:28 PM
dakota33's Avatar
dakota33
Am I missing something? Im taking the whole rear end.. why would I need to see the guts of the axle?
Old Aug 31, 2009 | 03:37 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If your taking the whole axle then skip all the internals. But getting off the U-Bolts can be a pain in the A$$. Depending how bad it is, I guaranty at least 1-2 hours to remove the complete axle. Your other option is take out the leaf spring bolts and take it all, and mess with it at home.
Old Aug 31, 2009 | 03:48 PM
dakota33's Avatar
dakota33
Ya, I will probly take everything then.. just to make it easier. Dont wanna have the hastle of taking it apart that much. But he has alot of **** there.. I would imagine he has a impact gun or something I could use... I hope lol
Old Aug 31, 2009 | 04:09 PM
skyshark186
I thought you were pulling just the guts. The whole rear would take less time than the guts to me.
You just need a 1/2 ratchet and a few sockets, and a heavy duty set of side cutters for the brake lines. Pop both the shackle bolts out on each side, cut the brake lines, and take off the 4 3/8ths bolts in the driveshaft and your on your way. Take a few wrenches to brace the backside of the shackle bolt/nut while your working on it.
Or just take an angle grinder and cut the ubolts, being careful not to cut the axle tube.
Old Aug 31, 2009 | 04:33 PM
dakota33's Avatar
dakota33
angle grinder it is lol..
I kinda just clued in now.. but what years have what gear ratio.. or are they all the same?..
Old Aug 31, 2009 | 04:50 PM
skyshark186
There were several different options from the factory. Only way to tell is if it has a tag or to pull the cover and count the teeth on the ring gear and the pinion.
Old Aug 31, 2009 | 05:01 PM
dakota33's Avatar
dakota33
damn it.. that sucks, because that means I would have the pull the cover on both?.. cause Im not even sure what my gear ratio is..
