Will this work in my 1992 Dakota?
Old Mar 30, 2005 | 04:53 PM
Blstr88's Avatar
Blstr88
Default Will this work in my 1992 Dakota?
Ive got a 1992 Dodge Dakota with a 5.2L V8 (318)...will this fit mine?
Ignition Control Module
DAKOTA
1990 5.2L 318cid V8 F/I
Old Apr 3, 2005 | 10:42 PM
injmopar's Avatar
injmopar
Default RE: Will this work in my 1992 Dakota?
A 92 will fit in a 90
Old Apr 12, 2005 | 01:35 AM
JDakota92's Avatar
JDakota92
It might fit, but I'm not sure it it'll work. 1992 was the first year of the Magnum engines. The ignition module out of a 1990 may not be compatible.
Old Apr 18, 2005 | 02:50 AM
injmopar's Avatar
injmopar
Sorry I should have said that the long block will fit right in.If I remember right the 90 still had the flat nose, so you have to use an electric fan.If you have the complete engine bay harness, its not that hard to mod it so you can use the magnum port injection.All you need is both wire diagrams.
88 Dakota 95 Magnum M1 intake
Old Nov 8, 2005 | 07:14 PM
360DakotaPwr's Avatar
360DakotaPwr
You will need to run a 92 up computer to make the multi port injection work.
