Nov 2, 2005 | 06:32 PM
Does anyone know if the 6 bolt rims for Chevy, Ford, or Toyota will fit the Dakotas?
Thanks for the help
Reply 0
Nov 2, 2005 | 06:34 PM
RE: rims
If they are the same bolt pattern and size meaning 5x100 or 6x120 or what have you...then yes they will fit on the truck...
and unless they are aftermarket rims, why would you wanna do that?
Reply 0
Nov 2, 2005 | 06:41 PM
RE: rims
what exactly does 6x120 mean?
thanks for the help
Reply 0
Nov 3, 2005 | 12:05 AM
RE: rims
All 6 bolt rims are the same.......Except for the newer dodge
Reply 0
Nov 8, 2005 | 07:05 PM
RE: rims
Only 6 bolt rims from a dakota, durango will work, but you MUST check the offset. Chevy and Ford will NOT work.
Reply 0
Nov 10, 2005 | 04:16 AM
RE: rims
The bolt pattern for chebby, and Toyo's is a 6/5.5" bolt pattern, meaning, there is 5.5" from center of one stud, to the center of the direct opposite stud. The Dakota and Durango and Viper pattern is a 6x4.5" pattern. They are not compatible. The Dakota pattern is a Dodge only pattern.
Reply 0
Subscribe
