door lock problem
Old Sep 17, 2009 | 01:52 AM
gambler12's Avatar
gambler12
Default door lock problem
95 Dakota with manual locks. Drivers door lock works hard..spray wd-40 in lock..works fine for a couple days then acts up again. Any ideas?
Old Sep 17, 2009 | 02:08 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Dirt built up. Bent or broken parts. Hard to tell unless you open it up and take a look.
Old Sep 17, 2009 | 03:13 AM
festerw's Avatar
festerw
I'd go with dirt build up, use some carb/brake/electrical cleaner whatever's handy and spray everything down then recoat everything with graphite.
The reason WD40 works for a few days is because it's mostly solvents with a small amount of lubricant, it dries up fairly quickly then you're right back where you started the graphite will be there for a good while.
