stroking
Old Sep 16, 2009 | 07:21 PM
allen6634's Avatar
allen6634
Default stroking
hi all i have a 93 dakota with a 5.2, it is getting old and weak ,i was thinking about going with a stroker kit from hughs. has anyone done this ? are there a lot of changes i need to make to the top end? and will my computer work with this set up ? thanks .
Old Sep 16, 2009 | 08:14 PM
95_318SLT's Avatar
95_318SLT
You don't have to change the top end, but if you want to make it worth your money, you should get a mild cam and roller rockers. Maybe even bigger injectors. Cam, head and valvetrain mods are where the real power is producd.
Also, you should look into getting a mopar performance computer for the new set up. The stock computer should run the engine, but you'll notice a bigger gain with the performance computer.
Also, if your going to go that far, you should think about headers, high flow air filter, and a bigger bore throttle body.
Old Sep 17, 2009 | 06:02 AM
allen6634's Avatar
allen6634
Default thanks
i was worried about the stock stuff choking it down, i may do some work to my heads and up grade my intake, i know this project will snow ball. i am mostly worried about the computor so i can keep my od tranny and my mpi. i realy don't care about hp this is to make my baby a towing beast.
