Rear Differential Oil Change
Old Nov 13, 2010 | 10:09 PM
  #21
MoparMan1995's Avatar
MoparMan1995
I see you already performed this but I wanted to mention a couple quick things that I didn't see anyone else mention:
-You can change the rear-end fluid without removing the cover by using a siphon or similar tool.
-You could always pick up a new rear-end cover for cheap (online buying=always cheaper)and paint it well before you even put it on.
-I know a few people who use and like POR15(paint over rust). You can apply it right over rust after cleaning it off a little, it lasts for a LONG time, and certain types have a shiny finish.
-Don't forget to change your fluid on a level surface to make sure you have the proper fluid level when you check to see if the fluid is flush with the bottom of the drain hole.
-You could try cleaning the drain hole with some wet Brillo so the smooth surface gives whatever plug you use in the end (preferably new) a better seal to help stop leaks.
Old Nov 13, 2010 | 10:59 PM
  #22
oxygen454's Avatar
oxygen454
Originally Posted by Crazy4x4RT
According to the FAQ "Rear Axle: 7-1/4" 1.4L, 8-1/4" 2.1L "
Thanks for converting it from Pints , now reading the faq but how do I know which one I have? Its 4wd but other than that I didnt know there was two different types?
Old Nov 14, 2010 | 12:34 AM
  #23
issakar's Avatar
issakar
If you're lucky the axle will have an ID tag bolted to it on one of the diff cover bolts. If not, like most of us (usually they get rusted/break/etc) you can go to http://www.ringpinion.com/DiffList.a...&Type=Chrysler and use the pictures to identify your axle. Alternatively, you can contact Chrysler and get the build sheet for your truck. This will tell you all the gritty details you wanted to know about your truck. There is a link in the FAQ for requesting a build sheet should you be interested.
Old Nov 14, 2010 | 12:54 AM
  #24
oxygen454's Avatar
oxygen454
Thanks, I will take a pic of her rear end and compare.
Old Nov 14, 2010 | 12:56 AM
  #25
issakar's Avatar
issakar
Too easy, lol :-p
Old Nov 14, 2010 | 01:06 AM
  #26
oxygen454's Avatar
oxygen454
Looks like its the Chrysler 8.25 Rounded and a 10 bolt pattern not squared like the 7.25. Not sure if its better than the 7 but its good.
Old Nov 14, 2010 | 01:52 AM
  #27
Crazy4x4RT's Avatar
Crazy4x4RT
Bigger is always better. The 9.25 is even better.
Old Nov 15, 2010 | 02:51 PM
  #28
MoparMan1995
If your also talking about what type of rear you have either standard or limited-slip, keep in mind the previous owner could have changed the internals from one type to another and you wouldn't know which you have unless you pop off the rear-end cover and take a look or stick a wire cam down on the hole. I found that out when my truck rear-end blew out over 3 years ago I wanted a limited-slip rather then just one-wheel-peel I had the option to either take the internals from the new rear and put it in the other or just change the entire rear. I opted to just change the entire rear since the drive train specialist said it would be faster and more cost efficient to just change the entire thing.
Old Nov 25, 2010 | 12:37 AM
  #29
413maxwedge's Avatar
413maxwedge
Originally Posted by 95_318SLT
1) The 1995 FSM recommends using 80W-90 gear oil. I assume there is no difference for '93. When I filled my differentials, I actually used Lucas Oil Stabilizer. It said on the bottle you can use 100% capacity in differentials, and it has worked out great for me. Also, if you have a limited slip differential, be sure to add 4 ounces of friction additive. As for capacity, its 2.1L, but instead of worrying about measuring it out, just fill it up to the bottom of the fill hole as long as you're on flat ground.
2) I would start by scrubbing it down with car wash soap and a green scotchbrite pad. This will get the oil and dirt off of it as well as start scuffing it up. Then, use 220-320 grit sandpaper, or if you have air or power tools, use a roloc fiber disc. I would recommend just spraying it with black rustoleum spray can paint.
3) That rubber plug is probably dry rotted. Replace it when you get the oil and while you're prepping it for paint, be sure to clean up the hole.
If you read up on lucus you should see it already has the friction agent in it for LSD's as does most of the gear oils today even synthetic oil.
Old Nov 25, 2010 | 12:42 AM
  #30
413maxwedge
Attachment 10919 click on pic
