1991 v6 dakota manual transmisson problems
Old Sep 28, 2009 | 04:35 PM
arabit's Avatar
arabit
Question 1991 v6 dakota manual transmisson problems
I recently bought a 1991 dodge dakota 3.9 v6 5speed and i found out that it doesn't shift into 5th gear or reverse. Now i think that it might be the shift linkage but im not for sure...so if anyone can help me out that would be greatly appriciated.
Old Sep 29, 2009 | 12:46 AM
Crazy4x4RT's Avatar
Crazy4x4RT
When you say it doesn't shift into 5th, does it not move into the spot or it just grinds? Give more details. Is the shifter stiff? Does it grind in any gears?
Old Sep 29, 2009 | 01:02 AM
95_318SLT's Avatar
95_318SLT
If the shifter won't go into the 5th or reverse positions, I would say either the linkage rods or the forks are damaged. If the shifter moves but the transmission won't go into gear, I would say the collar is damaged. If it goes in but grinds, I would say the sycnronizer is worn out.
Old Sep 30, 2009 | 01:46 PM
ScottD's Avatar
ScottD
Was the transmission rebuilt before you bought it? It could be there is an issue with the reverse lock out. I've seen that installed upside down and not allow 5th to engage.
Old Oct 1, 2009 | 08:46 PM
shelbydaytona's Avatar
shelbydaytona
where u at? i got a good trans from a 91
