Temp gauge
Old Oct 15, 2009 | 11:04 AM
bullwinkle's Avatar
bullwinkle
Default Temp gauge
OK I have a '93 Dakota, done some work with the help of this forum, and I appreciate the help I've gotten.
Now on to the next issue with the truck. The temp gauge doesn't work. The engine gets hot (heater works fine) but the gauge never moves. I know this probably isn't a major issue but I want things to be working like they are supposed to. I'm assuming it is either the sending unit or the gauge itself. What I would like to know is one or the other more prone to going out? If it is the sensor where exactly is it located and how difficult is it to change?
Thanks in advance for your help!
Old Oct 15, 2009 | 11:17 AM
skyshark186's Avatar
skyshark186
I would check the temp sensor. That would be far more prone to go out than the gauge, although its not impossible. Autozone should have them and a walkthrough.
Old Oct 16, 2009 | 10:26 PM
bullwinkle's Avatar
bullwinkle
Well replaced the sensor and guess what the needle moves now, just not as far as I would like it. It stops at the first line but has the heat going ok. Guess I need to replace the thermostat now. Looks like it might be stuck partially open. How much of a pain is it to replace since it's down in there behing the alternator braces and all?
Old Oct 17, 2009 | 02:06 AM
Crazy4x4RT's Avatar
Crazy4x4RT
it is possible it has failed or you have a low temp thermostat. To replace it may be easier to remove the alt. 2 bolts and leave on the wires.
Old Oct 17, 2009 | 04:54 AM
Wishihadahonda's Avatar
Wishihadahonda
my dak seems to run very cold according to the gauge i figured it was just normal. hmmm
Old Oct 20, 2009 | 05:07 PM
bullwinkle's Avatar
bullwinkle
Replaced the thermostat and the needle moves up to just shy of half way. I have more heat than I need for this time of year!!
