Bogging down problem
Old Oct 20, 2009 | 01:43 AM
shadowscolt45's Avatar
shadowscolt45
Exclamation Bogging down problem
i have a 95 v6 2.9 and i have a bog down problem. it runs just fine but everytime i stop at a stop sign and then push the throttle to go it bogs down just a bit. i have cleaned throttle body and replaced o2 sensor and fuel pump. i cant find anything else wrong. check engine light is not on can anyone help me?
Old Oct 20, 2009 | 02:02 AM
95_318SLT's Avatar
95_318SLT
Welcome to DodgeForum!!
Did you replace the fuel filter while you were replacing the pump? And has the truck had a recent ignition tune up? Just off the top of my head, it could one or more of: the TPS, MAP, IAT, or coolant temp sensors that have gone bad. The computer uses all of them to tune the engine.
Old Oct 20, 2009 | 02:15 AM
pioneerbirdy's Avatar
pioneerbirdy
I would think the computer would throw a code if its a sensor. But if the sensor half works then the computer might not see it as a problem. I would do what 318 suggests but i would start with the fuel filter.
Old Oct 20, 2009 | 03:12 AM
shadowscolt45
Default well...
when i replaced the fuel pump the fuel filter is equipped into the pump and has no in line fuel filter..and how do you check if the TPS and MAP sensors are bad?
Old Oct 20, 2009 | 03:16 AM
pioneerbirdy
Not to sure my self. I would think that the computer would throw a code.
Do you know how to check for codes?
Old Oct 20, 2009 | 03:20 AM
shadowscolt45
yeah thats exactly what i thought but no such luck... also i have two bulbs,one on each side, in the font headlights that do not work but arent headlights or blinkners and i was wondering if they have anything to do with fog lights or something..i have only had my truck since january and i have recently startin tearing it down to customize it
Old Oct 20, 2009 | 03:21 AM
shadowscolt45
and yes i know how to check codes...on off on off on for codes
Old Oct 20, 2009 | 03:26 AM
pioneerbirdy
well i am stumped then. as far as the headlights go i am not to sure. I don't think these trucks came with fog lights.
318 would know more about the headlights sence he has same year
Old Oct 20, 2009 | 06:35 AM
woodbutcher5691's Avatar
woodbutcher5691
Are they the small bulbs? Mine are and don't work either, I think they are just extra parking lights. I never saw the need for those two little lights so I didn't replace them.
Old Oct 20, 2009 | 02:59 PM
Coadster's Avatar
Coadster
EGR or TPS. Had the exact same problem, turned out to be the EGR, it had thrown the code, but didnt turn the CE light on.
