T-case slip joint
Old Oct 21, 2009 | 11:23 AM
festerw's Avatar
festerw
Default T-case slip joint
So I pulled my drive shaft to change the U-joint at the transfer case, when I pulled the shaft I got a fair amount of fluid running out. Never having pulled it out before is this normal? Only reason I ask is because it's above the fill plug so I was wondering if it was over filled or whether I've got a leaking seal. I haven't checked the fluid yet because I can't find my big frackin socket to pull the plug.
Old Oct 21, 2009 | 11:35 AM
95_318SLT's Avatar
95_318SLT
Yes, its normal. The slip yoke requires fluid to lubricate the splines and outer bushing.
Old Oct 21, 2009 | 05:37 PM
festerw's Avatar
festerw
Thanks, that's kind of what I figured but I thought I'd double check.
