2H or N on a 4x4 93'
Old Oct 26, 2009 | 10:06 PM
4x4Dakota93's Avatar
4x4Dakota93
Default 2H or N on a 4x4 93'
am i suppose to drive with 4x4 in neutral position or in 2H, whats the difference???
Old Oct 26, 2009 | 10:07 PM
4x4Dakota93
and i on this question i mean like when i dont want to be in 4x4 and im on the highway or just crusing around
Old Oct 26, 2009 | 10:12 PM
Crazy4x4RT's Avatar
Crazy4x4RT
2 high is for everyday driving. Neutral is for towing the truck. 4 high for when traction is needed. 4 low is for MAXIMUM traction.
Old Oct 26, 2009 | 10:32 PM
95_318SLT's Avatar
95_318SLT
Yeah, 2hi for on the street. Neutral is just like the transmission's neutral, it will disconnect BOTH driveshafts.
4HI is for dirt, gravel, deep snow, etc. It is a locked position meaning the front and rear axles are spun at exactly the same rate. When you turn, all 4 wheels take a different path through the turn, so they all travel a different rate. The differentials can take care of the right and left wheel on each axle traveling at different rates, but since the axles are locked together, one front wheel and one back wheel MUST be able to travel the same rate. Since all 4 wheels are rotating at a different rate, and one front wheel and one back wheel need to travel the same rate, driveline bindup occurs on hard, high traction surfaces. On loose, low traction surfaces, the wheels can slip to make up for the difference when you turn.
4Lo is the same thing, but is geared down more (2.72:1 on the np231 t case). 4lo does not give you more traction... you'll get the same traction in 4hi as you do 4lo, but have a lot more torque put to the axles and another gear reduction. It is used for climbing steep hills or crawling over rocks at a very slow pace and for pulling really heavy objects very short distances (like pulling your buddy out of a ditch :P).
Old Oct 26, 2009 | 11:04 PM
4x4Dakota93
umm lol well ive been driving it around in N forever, front drive shaft is in backseat of truck, so i should put it in 2H then i guess
Old Oct 26, 2009 | 11:06 PM
95_318SLT's Avatar
95_318SLT
You haven't been driving it in neutral. You can't drive it in neutral. You should check the shift linkage to make sure you're in the selection you think you're in.
Old Oct 26, 2009 | 11:44 PM
skyshark186's Avatar
skyshark186
If youve been driving in neutral youve been visiting the same place for a long time.
Like he said, thats not actually possible. Neutral is usually kindof a pain to get it into vs the other actual gear locations.
Old Oct 27, 2009 | 12:55 PM
4x4Dakota93
hmmm i checked, i took those stupid skull shift ***** off from 5 years ago and put stock ones back on, its seems ive been driving around in 4H but i dont have a front driveshaft in atm so i should be ok right? i went ahead and put it in 2H
Old Oct 27, 2009 | 01:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya you should be okay. The 4wd light should have been on to tell you it is in 4wd, unless the light bulb is dead. Why did you take off the driveshaft?
Old Oct 27, 2009 | 01:59 PM
skyshark186
Asside from getting worse mileage it shouldnt have hurt anything unless you drove it at a high rate of speed.
