pulling codes????
To pull codes, you cycle the key "on...off...on...off...on" without starting the engine and then count the flashes by the check engine light. All codes are 2 digits, so there will be a pause between the first and second digits, and a longer pause between the next code. 12 is beginning of codes, 55 is end of codes, so if you see those, don't worry about them.
Example:
flash...flash...flash...flash...flash.........flas h...flash...flash...flash...flash would be 55.
Example:
