Stalling
Old Nov 27, 2009 | 03:09 PM
larter5's Avatar
larter5
Default Stalling
1992 dakota,5.2.auto
this all happened with in week
first thing that happened was my transmission started reving high maybe 50kilometers before it would switch gears,checked trans fluid turned black,..
the next day the truck started stalling in reverse if it was on flat ground
the next day started stalling right out of gear,whether i put it drive or reverse,this is not just once in a while it is ever time.If i hold my foot on brake and push allot of gas and switch gear it will stay going and move.
so first thing i did was change gas filter,NO LUCK
next was put ground wire from engine to motor,no luck.
Did a bunch more readiing and video watching,took out iac and cleaned it,put it back in still no luck,
with more reading somewhere i read maybe the crankshaft sensor.i found a video on how to test it but can't locate it under my hood?
I am not mechacle inclined on my own but if i watch videos and talk to people i get the job done..
so if anybody can lead me to the crankshaft sensor would be great and if you have any other info i can use please let me have it.
Thanks James
Old Nov 27, 2009 | 04:32 PM
skyshark186's Avatar
skyshark186
Sounds like your torque converter may be fried. Sorry bud. Or perhaps the clutch packs in your gears themselves. Change your tranny oil and see whats in the pan.
The crankshaft sensor is on the passenger side of the motor towards the top. Maybe 5 inches from the distributor between the rear of the motor and the bellhousing.
Old Nov 29, 2009 | 01:28 AM
larter5's Avatar
larter5
Default stalling
thanks for the reply.
I will check out the crankshaft in the am.
do i need a gasket for the tranny pan?
Old Nov 29, 2009 | 01:00 PM
blackandsilver95's Avatar
blackandsilver95
yes just go to the local parts store and ask for a tranny filter and gasket for the truck no more than 10 bucks
Old Dec 1, 2009 | 12:55 PM
larter5's Avatar
larter5
does disconnecting neg battery reset puter?
Old Dec 1, 2009 | 01:20 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it does.
