Need help on 95 dakota
Old Dec 8, 2009 | 12:18 AM
daneek155's Avatar
daneek155
i checked for vacuem leaks and they are good. when i just start it the brake pedal goes down halfway like normal. but when it starts to brake itself the pedal is super sensative. i am going to go with a new master cylinder and brake lines. you guys know where a good place to get a master cylinder. thanks alot for info
Old Dec 8, 2009 | 02:18 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Most reliable place to get a new one is dealer or Napa. Don't wast your time with cheepies. They will fail.
Old Dec 8, 2009 | 11:46 PM
daneek155's Avatar
daneek155
ok so i ordered my master cylinder at napa should come in today. is there a special way i should bleed the brakes or just bleed them like regularly, back right to back left to right front. it has abs. anyone have trouble with bleeding before
Old Dec 8, 2009 | 11:55 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Bleed the MC first. Just install it. Hook up the hoses that it comes with. Fill up the reservoir. Pump the pedal until no air come into the lines. Then hook up the lines and bleed the system. It should include instructions with it.
Old Dec 10, 2009 | 09:45 PM
daneek155's Avatar
daneek155
thanks a lot for all the info. i changed my master cylinder and brakes work great now
Old Dec 11, 2009 | 12:10 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Cool Im glad you got it.
