need help
Old Dec 12, 2009 | 12:30 AM
dmarcum123's Avatar
dmarcum123
Default need help
I have a 95 dakota 3.9 it missing bad like it is smothering to dead when push it to the floor.I replace plugs,wires , distributor cap,roto button ,fuel pump,coil ,computer, truck has 140,000 miles on it.
Old Dec 12, 2009 | 12:37 AM
ramitt360's Avatar
ramitt360
Check the timing?
Old Dec 12, 2009 | 12:50 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Check the timing and plug wire location.
Old Dec 12, 2009 | 01:03 AM
95_318SLT's Avatar
95_318SLT
+1. And if you still can't find it after that try replacing the crankshaft position sensor and/or camshaft position sensor and/or distributor pick up.
Old Dec 12, 2009 | 09:06 AM
dmarcum123's Avatar
dmarcum123
ok guys never work on a dodge can you tell me how to check the timing .i have another parts truck wanted to try whatever before i have to tear it down to put timing set in.
Old Dec 12, 2009 | 01:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
For the timing you want to put the #1 cylinder on Top Dead Center on it's compression stroke. Then look at the distributer and make sure the rotor is pointing directly at the #1 spark plug wire. If you need more info go to the service manual we have located in the FAQ in this section. Go to sect. 8D pg 22.
Then make sure the plug wires are in the correct spot. The Firing order is on sect. 8D pg 26.
Old Dec 13, 2009 | 04:37 PM
dmarcum123's Avatar
dmarcum123
well i did all the above and no luck so. i had one thing to do cut the converter off and that was where it was at. put a piece of pipe in it and runs like a new truck
Old Dec 13, 2009 | 07:27 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Cool! Glad you got it. So you never had a miss then.
Old Dec 13, 2009 | 09:14 PM
dmarcum123's Avatar
dmarcum123
no it was smothering to dead the exhaust was close off .you give it gas and it would shake like a miss
Old Dec 13, 2009 | 10:51 PM
ramitt360's Avatar
ramitt360
Ahhhh yes i didn't even think of that. A friend of mine had the same problem with his truck and we couldn't figure it out until we happened to look under the truck and saw the cats glowing orange hah
