Heater problem...NEED HELP!!
Old Dec 12, 2009 | 09:27 PM
Dodgeman_87's Avatar
Dodgeman_87
Default Heater problem...NEED HELP!!
I have a 1994 Dodge Dakota sport with 4x4 and the 3.9 v6. It has a new heater core and thermostat and the heat works...barely. It doesnt get very warm at all, hardly even takes the frost off the windshield. Have any ideas??
Old Dec 12, 2009 | 10:18 PM
96_dakota's Avatar
96_dakota
have you flushed the radiator?
I have the same problem with mine, i was working of flushing the radiator at work and only did a half *** job cause we got busy, but it seemed to help a little.
Old Dec 12, 2009 | 10:29 PM
95_318SLT's Avatar
95_318SLT
What temp thermostat did you put in? If its the 195 there should be no problem, if its the 180, it won't produce much heat.
Otherwise, it might be air in the heater lines or core.
Old Dec 13, 2009 | 01:02 PM
burntricer's Avatar
burntricer
does the fan just blow slow? or is the temp gauge reading low?
Old Dec 13, 2009 | 01:08 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Your selector doors may not be working as well.
