Power steering fluid sprays straight up from somewhere back of the pump. empties the pump in about 1 minute. Eliminated lines as source(covered with rags and still had spray all over the engine. Decided to remove the unit. With everything disconnected except the high pressure line, discovered the 1" union where the high pressure line connects is not tight (it swiveled). Could this be the leak?
